03-11-2017
06:12 AM
- last edited on
03-06-2024
09:03 PM
by
ROGBot
01-02-2019 05:03 AM
xeromist wrote:
Could be a lot of things. First ensure that the cable is fully seated. It should lightly snap into the port. You will need to select the proper playback device in Windows. Make sure to choose the digital output and not the normal output or HDMI. Windows 10 will only output one at a time. If the cable is seated and active you should see a pinpoint of red light visible on the opposite end of the cable.
As an Onkyo owner myself I know you also need to make sure that the optical connection is assigned to the input you are selecting. Consult the receiver manual on how to ensure this is the case.
