11-27-2025 10:09 AM - edited 11-27-2025 11:08 AM
hi
The monitor PG32UCDM ON MCM108 FIRMWARE
The problem is that the hdr when is activated on windows . The monitor switch on hdr perfect . When i went desactivated the hdr on windows the monitor freeze completely . When I press on the buttom power on the case the pc turn off the pc is not freeze just the monitor.
I try a new cable , too without other screen same problem.
The problem is on hdmi2.1 or dp1.4 on rtx5090
When i switch of monitor a msi on dp1.4 mag274upf . The hdr work well i can turn on or off and the monitor doesn't freeze.
The problem is the firmware of Asus.
I send the monitor at Asus
