Fixed random shutdown and Fan noise of my Swift PG 27UQ
Richu6
My Asus Rog swift PG27UQ was starting to randomly goes off, after about 1 hour.
And the Fan was very loud.
In some reddit posts i found people with the same issues, and they did try to fix it with an extra Fan behind the Monitor or with replacing the thermal paste.
I decided to go a different way, and get completely rid of the Fan.
I disassembled the whole thing, and was looking for options to watercool this thing.
Luckily i found a waterblock that could fit in. And in the inside was enough space to route some soft tubes.
The final result is looking fantastyc. And works perfectly!
I love to not longer have the noisy fan in my silent room!
And no shutdowns so far with the mod!
0 REPLIES 0
