Bug Report: PG27UCDM power indicator will not disable in standby mode
KylePolansky
I have the option "System Setup > Power Indicator" disabled. I would like the power indicator to remain off regardless of monitor power state.
When the monitor is turned on, the power indicator is disabled as desired. However, when the display goes to sleep, the power indicator turns on with an orange color.
I recently upgraded the PG27UCDM firmware from factory version 101 to latest version 105. Previously on version 101, the power indicator would remain off in both powered on and standby modes (as desired). I suspect something in the firmware update broke this behavior.
Irlluke
I’m also having this issue. So annoying as I need complete darkness to sleep.
