Wireless Problem for G750jw
Change
So i bought a new asus g750jw a few days ago it worked perfectly fine for about 4 days then starting yesterday my wifi connection would start disconnecting and reconnecting every few minute i would like to know how to fix this. I've try to uninstall and reinstall the drivers and tryed to update it. If it helps i have the Qualcomm Atheros Ar9485wb-eg wireless network adapter.
Hope you can all help me 😞
The_Jackal
For Windows 8.1, a new driver was released today: http://dlcdnet.asus.com/pub/ASUS/nb/DriversForWin8.1/WLAN/WLAN_QualcommAtheros_Win81_64_VER1000279.z...
for Windows 7, the best driver is
I jad many disconnection issues with the official driver posted on the asus website for the G750JX which is 10.0.0.268 but the later one solved the problem. I used to randomly get disconnected from my ASUS RT-AC8U all the time
Change
so what should i do? is the asusg750 compatible with other wireless network adapter? if so which one works best. Thanks in advance
