Vivobook 16x pro oled connection to external monitor
Hollowcow
Hello,
I want to connect the Nvidia 4070 gpu inside the laptop directly to a samsung odyssey oled g8 34 inch monitor that support mini dp and mini hdmi inputs.
The monitor has a resolution of 3440 x 1440 and 165 hz. 10 bit oled with g sync support.
Which output of the laptop fully support this monitor at 165hz and connect directly to the dgpu for best preformence? The hdmi output on the left or the thunderbolt 4 output on the right?
I will use the external monitor for gaming and I need low respond time and lag free.
Also which cable fully support that specs?
Hollowcow
Any help please?
