Trick for boost fan speed
nostrora
Hello, i've found a little trick for boost the speed fan of CPU and GPU.
This trick allows you to put the fans at their maximum speed. For cons, I still do not know how to get them in the normal state (I try)
For now, you are forced to shutdown properly your laptop
Work with lot of G asus
Check !
1 / Download this : http://rweverything.com/download/
This software allow you to modify the ACPI table 😉 ( fan of G laptop work with ACPI table )
2 / Open the software and click on EC icon :
3 / Change this value to 1 (double click and set it to 1)
For now, the only solution for get back into normal state, is shutdown computer (not restart)
Bye bye
Clintlgm
Level 14
First thing I've seen that changes anything about fan Speeds. But then what would be the purpose for doing this, The G series fans work perfectly according to the temp of the CPU. Full Speed would just be loud all the time.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
nostrora
I agree, it was just to "test" the temperature in overclocking. I wanted to make sure my fans running in full speed
Ic
980m GTX 4 GB
Windows 10 Pro
Z97 -A
Windows 10 Pro
