To those with G75 subwoofers producing the full range of sound, not Low Freq.
X-ROG
Level 15
Please sound off so I can count you. Sorry for so many threads, it's difficult to see how many when there are many discussions of varying fixed stages in the other sound threads.
Please answer me this quickly:
1) Which drivers: 10200/10400/10500b.
2) Did you full remove the old VIA HD Audio Deck and restart before updating them? (Yes/No). If not - can you do so again to try as the software won't update properly if it's not a clean install.
62 REPLIES 62
toronto699
Was This Audio Issue Ever Fixed for the G75? now newer G series have an issue with audio {G751}
http://rog.asus.com/forum/showthread.php?54313-G751-Imbalanced-Sound-Problem-OFFICIAL-SUPPORT-THREAD
tweek
same problem tried so many different suggestions with no change
tried a clean uninstall/reinstall of audio drivers with ones on website
There is no solution, we can make it sound better but the subwoofer will never be a sub woofer. from .800 ver on it is not even called a sub woofer it called a bass speaker and continues to play full range sound. I have gotten used to mine and don't really care any longer. If I want to hear accurate music hd music I put on quality head phone.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
