So what do I call this G751JY-DH71 power-on problem?
rodney4555
When I press the power button, nothing happens.
I just got it, never used it... Bought it in the US thru Amazon, now im back in my country the Philippines.
https://www.youtube.com/watch?v=y8ElqWtat1c
its a G751JY-DH71
22 REPLIES 22
Richard2137 wrote:
Hi Alevi, did you get your black screen on power up problem fixed as my laptop does the same thing. When I shut it down and then press the power button to start it I get a blank screen however I can tell the laptop has started, if I press the power button again to put the laptop to sleep then press the power button again to wake the laptop the screen works. It seems to only have the black screen problem when I start the laptop from a shut down. Turning on from sleep seems to work okay.
Any suggestion would be grateful.
Richard
No Solution
Return it if you can
Everyday when I try to power it on to work I have an black screen and I have to reset it 2 or 3 times to load bios and get into windows.
Asus don't care...
Thank you for responding. I will let you know if I have any luck.
rodney4555
nope, 1st time I opened it, then that happens... haven't seen it boot yet
So...you bought it in the U.S. - didn't bother to power it on while you were within the U.S. - and now you have this issue? Wow, that's some bad luck.
4710HQ, 980M // 5930K, 980 SC SLI // 4930K, 980 SC // 4770K, 290X Lightning // 1pcent.com
lol, I was on my way to the airport when laptop arrived, so did not have the time to test it, even if I knew then, I won't have any time to return the laptop, when I bought the laptop, I just trusted that asus will give me a working one, lol. yup bad luck indeed.
cl-Albert
US Customer Loyalty Agent
its a G751JY-DH71
Saw your PM about this and feel free to discuss privately if you prefer.
Yes, since you aren't even able to get the unit to power-on long enough to get into the bios, thought we may want to check into your AC adapter and power outlet more since it's not too likely a brand new unit would not stay powered on and work.
1. From what I've heard you may not use standard U.S. plug outlets in your country, so wondering if whatever 'plug or voltage converter' you are using to plug it into the wall could be causing any problems?
By the way if you check the specs printed under the 'international' 230W AC Adapter bundled with the G751JY, you will see the input voltage goes from 100-240V which should mean you don't need to use a voltage converter.
You can plug that 230W AC adapter directly to your wall outlet as long as you could find a converter for the plug.
If you can find another power cord only for your country that fits the 230W AC adapter, this may be another approach, but just make sure the replacement cord can handle the current and does not get too hot to avoid the risk of fire danger. Don't expect it would be too difficult to find the right power cord, but you might check with your local ASUS offices if necessary.
2. Try a different outlet/power strip if you haven't already.
3. If you are able to fully charge the battery at least (the battery light should turn from blinking orange to solid orange to solid green), try to power on the notebook just with battery power and check items #1 and #2 above again.
Good luck!
Good luck!
yup, 1 and 2 is ok, I fully charged my laptop, and was solid green. It still won't turn on. So I just went and gave it to an ASUS service center here in my country, thankfully it has a global warranty, they told me to call them again in 3 days, and I need to wait 45-60 days if parts of the laptop are needed to be replaced.
Just my luck I guess. T_T , never had this problem when I bought my, G73 and G75.
Alevi
This is not only your notebook.
There are at least 10 people here in the forum with same problem.
Watch My Video
https://www.youtube.com/watch?v=LR9KMVT4c_g
Watch My Video
If you watch my video, you will see that mine doesn't even turn on, its not that it has black screen, it has nothing at all.
Power button just lights up for 1 sec
You can add me to the list. I also have that problem. Another problem I have is every now and then when the computer sleeps, after I woke the computer everytime I right click on an icon on my desktop or just right click anywhere on my desktop the featured menu will show up in a flash then
will turn into black. What are the fix for these issues? Thank you for your time reading this.:)
