Replacement Power Cable for XG Mobile 4090?
pandehz
I accidentally left behind my 3 pin power cable for the XG MobIle RTX 4090.
It's the cable that connects from the wall to the XG Mobile.
Where can I find a replacement and what would it be called?
Any help is appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
Hi @pandehz
Bummer! Yes that should be fine.
Hi @pandehz
That worked.
Thank you
