07-08-2012 07:46 PM - last edited on 03-06-2024 08:16 PM by ROGBot
07-09-2012 01:59 AM
07-10-2012 12:36 PM
Gorman wrote:
If you hibernate it instead of turning it off (save state, but don't use power) then you can set your USB drivers to be allowed to wake the computer.
Apart from that, or using WOL that is about it.
EDIT: Though I'm sure you could sneakily position a paperclip or such so that you can use it to turn on the computer without opening the screen.
07-10-2012 12:49 PM
