The problem started with just little lines that appeared horizontal and vertical. After around 4 days the screen went completely unreadable (as you see in the picture above). I cannot see a single thing through startup and well to anything.
Any solutions would be much appreciated. Thank you.
-- Attempted Solutions
- Plug in to HDMI and connect to TV to see if screen shows (Fn + F8). -- Nothing showed up and no signal was found. But then again even pressing (Fn f8) on startup and not even in windows does that option work?
