Possibility of Turning/Reusing parts from a (non-working) G551JX laptop into a PC?
SnailVendor
Hello everyone,
So I've got a ROG G551JX laptop which unfortunately died on me not too long ago. It's out of warranty and the guy at the repair shop I brought it to told me the motherboard suffered a serious short-circuit. Ultimately, it would have been just as expensive to replace it as buying a new laptop would have, so I resigned myself to buying a new one, albeit much less powerful than the G551JX.
However, now that I'm left with what is for all intents and purposes an expensive paperweight (the laptop doesn't even turn on anymore), I've been wondering what to do with it. Simplest solution would be to sell it for parts online but that gave me the idea of scrapping the laptop for parts and turning it into a desktop PC. I'm assuming the GPU, CPU, Screen, DVD drive, WIFI card and RAM still work fine (and I've already removed the HDD to turn it into an external HDD) so I was wondering whether it would be possible to reuse those parts to save me some costs in building a proper gaming PC? However, with my very limited knowledge in building PCs, I'm not even sure this is feasible, hence why I'm asking you knowledgable lot.
Any advice would be greatly appreciated!
Thanks.
5 REPLIES 5
Gps3dx
Level 12
quick answer: 0 chance.
you would be better off selling the parts that you can scrape out, and buy a PC.
Asus G751JT
Samsung EVO 850 120GB + 1TB HDD 7200RPM
Cleaned installed Win 10 HOME
My Guides:
  • [POST=538713]ROG LAPTOPS: COMPLETE DRIVER LIST ![/POST]
  • [POST=538713]How to install windows 8/8.1/10 on any UEFI supported laptop the PROPER way[/POST]
  • [POST=538711]HOW TO (EASILY!) UPGRADE FROM WIN7 SP1/8.1 WITHOUT GOING THROUGH THE UPGRADE PROCESS ITSELF ![/POST]
  • [POST=605307]HOW TO REMAP FN+KEY AND SPECIAL BUTTONS: "STEAM", "ROG" & "SHADOWPLAY"[/POST]
  • [POST=539663]Win 10 x64: SETUP USB @SUPERSPEED, NO HANG-UPS! | ACCELERATES USB 3.0/2.0 TRANSFER RATE SPEED TWICE![/POST]
Then again nothing is impossible if your willing to put enough money into it. I agree with GPS3DX just buy you a new notebook and save yourself a lot of money and aggravation.
Notebooks are nothing like desktops that you can just change a few parts, they have all that Desktop stuff jammed into that little 15" notebook most of its soldered in place or just proprietary made just to fit in that notebook
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
Korth
Level 14
Quite an assumption since it's a dead machine and "the guy at the repair shop" told you "the motherboard suffered a serious short-circuit". Any component salvaged from an electrically-damaged mainboard is automatically compromised and has dubious reliability. There's a reason the thing won't even turn on anymore. I would expect some sort of evidence supporting such a serious technical diagnosis - maybe point out some of the burnt/killed hardware components, maybe a photograph showing ugly damage, etc - it kinda sounds to me like the guy wasn't interested in even doing the job, didn't know how or didn't think it would be profitable enough, etc. From a customer perspective it's unreasonable to pay more for a repair than the cost of a replacement - and replacement G551JX parts might be available inexpensively if you do some digging.
Laptops typically have certain modular components - like memory and storage - which can be swapped out and used in other machines. Many have internal parts with standard form factors - Mini-PCIe WiFi card, GPU MXM module, etc - which could be swapped out and used in other machines. The battery can also be used in other laptops within the same laptop brand/model/family. All other parts are usually fully embedded (permanently soldered in place) or follow standard form factors (display panel internal DP ribbon, mobile processor socket, etc) but have hardware specs/quirks which are incompatible with the vast majority of other laptop models/variants.
You admit that you don't have knowledge or experience with building PCs. Attempting to salvage parts from a dead laptop is not the best place to start - it's a technologically dense machine packed with clever engineering, merely taking the thing apart and putting it back together (properly) will be a challenge for inexperienced people, while troubleshooting hardware faults and extracting internal parts (which aren't easily accessible through chassis access panels) will effectively be impossible. Desktops and laptops basically use completely incompatible hardware - and even if you could turn your laptop parts into desktop parts (it's not impossible if you understand PC hardware and some electronics) you would find that it's not worth the effort. After all, your laptop died and won't even turn on ... and it's out of warranty so it's basically "old tech" which won't make a great gaming computer ... and in the end this sort of project would basically cost you more than the price of a new (and working, and better) computer.
I advise donating it to a charity like Free Geek, or simply sell it on eBay (as a "dead, for parts" machine). Either way, your dead paperweight might be repaired, refurbed, reclaimed, recycled, and repurposed ... and you can already forget about making money from it, if what you've been told about it is true then it already has effectively zero value. You might want to take it to a different repair shop to get a second opinion, indeed you might even be able to sell it to them ("for parts") or trade it in as credit towards something else.
[/Korth]
SnailVendor
Thank you all for your replies and your great insight. As Koth suggested I took it in to a different repair shop for a second opinion and got pretty much the same conclusion. Guess I'll see if anyone on Ebay wants to buy it otherwise I'll look at donating it to a charity or recycling it.
Thanks again!
Korth
Level 14
The drive(s) and RAM could be used in other laptops. The CPU and GPU might also be useful in other laptops - if they still work, and if they're socketed/removable.
The battery, screen, and keyboard could be used as replacement parts for other ROG G551 laptops. (Any part could be used as a replacement, if it still works, though these are the parts which most commonly fail/break.)
[/Korth]
