09-25-2015
11:58 PM
- last edited on
03-06-2024
01:56 AM
by
ROGBot
09-26-2015 02:53 AM
09-26-2015 04:45 AM
edweird wrote:
i don't know about the internet issue - may be router related. I had to turn off some stuff related to dns and dhcp on mine to have no issues.
09-26-2015 06:40 AM
Edweird wrote:
I don't know about the internet issue - may be router related. I had to turn off some stuff related to DNS and DHCP on mine to have no issues.
The temps are relatively normal. Expect to see the same ones while playing The Witcher. The GPU ones are completely fine, the CPU ones are a tad high. Recommend using Intel XTU to drop core voltage offset by at least -75mV.
09-26-2015 07:07 PM
Edweird wrote:It is still beyond my comprehension how you guys get the voltage offset that low.Do you mean both core and cache clocks because with me everything below -30 is RIP.
09-26-2015 04:58 AM
09-26-2015 06:38 AM
Gps3dx wrote:
about the internet problem... its more like a wifi card problem i think.
With what driver are you currently running ? ( i.e the intel wifi card )
if it isn't a driver from the past month of so, provided by INTEL (not MS!) then goto intel support site and download intel Proset driver for win 10 x64
i'm currently working on my intel AC 7620 wifi card with intel driver v18.20.0.9 date 23/8/15 everything is ok ( I don't play online, but I do download @4Mb/s+ without any problems.
09-26-2015 08:41 AM
