Please help me with screenshot color issue [solved]
ROGaddict
Okay so whenever I use prnt screen or snipping tool or ANY thing that gets a snapshot of my screen it saves darker than the actual image.
When I take the snapshot and look at it it is perfect, but then after i save it as anything (png jpeg you name it) then if iI open the image is appears darker than the original, but if I were to put it online it will regain the original colors.. Any help??
ROGaddict
Ok nvm I fixed it, I had to delete my color profile
