Need help please....keeps going to automatic repair loop?
tnt2v2
For the past few weeks my g750 have had some issue on response time
Now couple days ago it has gone intot the stage of not working
I rebooted the system by pressing the button (only option possible)
and it went on the automatic repair loop...
I factory reset and got it working but the next day the same issue happen
Where the laptop was not responding and I had to force boot.
Again it went on a loop of never ending.
I just finished doing a 2nd reset and haven't touch since.
I was wondering if anyone have had the same issue and somehow
Gotten fixed.
tnt2v2
Gotten fixed.
So i did another factory reset and it will boot after like 10min but i cannot do anything... like i cant even do a right click and try to make a new folder or ETC...
Could this be a hardware issue? i dont think its a window issue now.
I still have my 1 year warranty and I was wondering if i send it it if they will charge me for labor and etc crap **hidden fees**
Maxter
did you try doing a full recover mode? the partition should be in the HDD. you can possible try some peripherals in order to navigate... it might be a driver issue (if not, likely to be hardware)
If the problem is because of manufacturing, they shouldn't charge you. Usually, they try to keep the customer happy. Maybe contact them via facebook to give social tension. They'll provide you an RMA right ther (I've done for other things, so far not for a laptop)
