Need help ASAP. ROG G752VS: Samsung SSD 950 PRO and winload.efi error
Spellman
Good day.
Almost 3 years ago i bought g752VS and Samsung 950 PRO SSD 256gb. Guys in shop helped me to install windows 10 and NVME driver.
Since then no problem occured, until this day.
Nothing new: no drivers, no programs etc were installed that day. Windows update turned off. Played the game as usual, turned off pc. In the morning I see error that system cannot be loaded,and file " \windows\system32\winload.efi" cannot be found or has errors. Code: 0xc0000225
In bios I cant see my SSD in boot devices, but im not 100% sure it was there ever.
When I open some windows recovery tools from flash drive, i can see that my drives have different letters (C: System became D:System). I can work with files, copy them, so i guess SSD is working.
When i try to reinstall windows on SSD drive, it shows error that drive is in GPT format and that I need to be sure that this drive is visible in BIOS.
Sorry for bad english and lack of explanation. My system has another language...
I need your help asap, because in few days I need to take my laptop at work.
Gps3dx
Level 12
please see my guide ( in sig ) about how to install windows UEFI method - in it you can understand how to properly boot windows installation disk/usb so it pass that error you reported about it not being GPT. ( i.e by booting it through UEFI instead of "bios" )
that guide is also a sticky thread at the top of our G-serie sub-forum.
if the SSD ( and its partitions ) isn't visible at all when windows asks you to choose a partition for the installation - then you need to follow the guides I linked at the top of that guide - because your SSD might work using NVME ( not AHCI ) which might need a spacial driver loaded during windows installation procedure inorder for the SSD's partition to be visible.
good luck.
Asus G751JT
Samsung EVO 850 120GB + 1TB HDD 7200RPM
Cleaned installed Win 10 HOME
My Guides:
  • [POST=538713]ROG LAPTOPS: COMPLETE DRIVER LIST ![/POST]
  • [POST=538713]How to install windows 8/8.1/10 on any UEFI supported laptop the PROPER way[/POST]
  • [POST=538711]HOW TO (EASILY!) UPGRADE FROM WIN7 SP1/8.1 WITHOUT GOING THROUGH THE UPGRADE PROCESS ITSELF ![/POST]
  • [POST=605307]HOW TO REMAP FN+KEY AND SPECIAL BUTTONS: "STEAM", "ROG" & "SHADOWPLAY"[/POST]
  • [POST=539663]Win 10 x64: SETUP USB @SUPERSPEED, NO HANG-UPS! | ACCELERATES USB 3.0/2.0 TRANSFER RATE SPEED TWICE![/POST]
