11-08-2018
04:50 PM
- last edited on
03-06-2024
07:49 PM
by
ROGBot
11-09-2018 04:17 PM
jdfrench3 wrote:
What model of laptop are you working on?
11-10-2018 12:48 AM
11-10-2018 02:06 PM
jdfrench3 wrote:
The ASUS support page has wireless LAN drivers for Intel and Qualcomm Atheros adapters. The G750JY doesn't come with the Killer N-1202 adapter. BEFORE the killer adapter can be installed, all previous wireless LAN adapter (and Bluetooth drivers) must be removed. Any other wireless LAN adapter drivers should not be installed while the Killer wireless LAN adapter is in place, damage could result.
I suggest all wireless LAN drivers be uninstalled, remove the Killer wireless LAN adapter and install the original wireless LAN adapter. Then install the original wireless LAN adapter (and Bluetooth) drivers. Now check that all is well.
Now if that went well, uninstall the original wireless LAN (and Bluetooth) drivers, remove the original wireless LAN adapter and install the Killer wireless LAN adapter. Then install the Killer wireless LAN adapter (and Bluetooth) drivers. Now check that all is well. If the 5G signal is still a problem, then the Killer wireless adapter is bad.
That's a lot of work, you might consider just buying a new wireless adapter. I would recommend the Intel Dual Band Wireless-AC 7260 2x2 Network plus Bluetooth adapter (7260.HMWWB.R).
Good Luck.
11-10-2018 03:20 PM
