I've absolutely had it with ASUS sound problems.
Jfrench
I downloaded a driver update and now the speaker doesn't turn off at all when I put the headphones in. This happened right after the driver was installed. I'm getting sick and tired of this crap. Is ASUS staffed by monkeys or something? How do you fix this?
Pitcher1
what is your models and audio driver version?
Clintlgm
Level 14
Well unless you have some sort of hardware problem these issues have been solve with the 600 and higher VIA Driver c_man put up some settings to make it sound better. Several other have also. If you haven't you may want to uninstall the VIA HD Drivers from Device Manager Program and Features reboot then install the latest drivers 1400 I think.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
GottiBoi55
Model #, and VIA, or SonicMaster sound card please!
PS: my guess would be "Monkeys" lol Just joking!
GottiBoi55
Asus
G750JZ-DS71 Windows 10 Pro (x64)
Intel® Core™ i7 4700HQ (2.40GHz)
Samsung
24GB Memory DDR3 1600 MHz SDRAM
SanDisk
M.2 SSD 2x128GB in Raid 0 / WD-HGST-1TB HDD 7500-RPM
NVIDIA® GeForce® GTX 880M 4 GB GDDR5 VRAM
Second Monitor: Shar
p Aquos 32"
