How to fix G750jm shutdown problem?
TheDragon
Hello!
I am a proud owner of an Asus G750jm (with Linux Ubuntu dual bootable, because Windows was behaving badly).
Sadly my computer has started to shut down everytime I disconnect the charger, and when it is connected it stays on 1% all the time. Before anyone says something, no it is not Linux' fault as this was happening ages before I switched. Is there any possibility that I can fix this on my own or do I have to buy a replacement battery, if the latter where can I find one?
Thanks for all the help!
You are supposed to smear the cooling paste behind the CPU on the pins, right?
jdfrench3
Level 12
Replace battery:
ASUS P/N: 0B110-00200000 or 0B110-00200000M
Amazon $40.
G752VSK, G75VW-3D, G51J, G1S
Homebuilt Windows Server
How do I know which one and is it worth it to replace as it is getting quite old?
Either model battery will work in your laptop.
If you like your laptop, keep it. Otherwise buy a newer laptop. That is a question only you can answer!
