09-04-201603:21 PM - last edited on 03-06-202401:47 AM by ROGBot
Mine is almost too hot too touch while gaming. Normal? Just the other day, noticed that the battery level has started dropping, from 99% or so to 90-ish and then the orange battery light switched on. But it still says it is charging. Tried taking the battery out, heat level of brick is the same. Have to admit I never tested adapter heat while gaming before, but with regular use, have never had it this hot.
