01-19-2014
05:38 AM
- last edited on
03-05-2024
11:54 PM
by
ROGBot
01-19-2014 06:15 AM
01-19-2014 06:18 AM
rogeirik1989 wrote:
hey im not quite satisfied with my asus g750jx
works like a dream in bt4 and need for speed rivals with the dc connected but when i unplug the games starts to lag when i'm
use my battery i dont understand why
somebody know how to fix this?
a friend of mine have the same laptop and don't have that problem:(
thanx for help
regards Eirik
01-19-2014 07:47 AM
hmscott wrote:
The G750 won't run the GTX card at full performance on battery, it is too much of a power draw, so it goes into power saving mode. You need to create game settings for AC and Battery, or play games on battery that aren't as demanding graphically.
Your G750 will last a lot longer than your friends laptop on battery, especially if his laptop isn't putting the GTX card into power save mode and he plays games while on battery.
01-19-2014 08:12 AM
01-19-2014 09:34 AM
01-19-2014 10:05 AM
01-19-2014 10:55 AM
rogeirik1989 wrote:
i have the latest bios 209 i installed it a few days ago but no change. i do change the performance plan to high performance when i unplug but the cpu does still do the same
does anybody else have similar problems?
i have tried power4gear and windows plans nothings work
i run windows 8.1
01-19-2014 02:58 PM
01-19-2014 02:13 PM
