Do You See White Colour Dots On Top Of The ROG Button? I Know That You Cannot See It Properly Because Of My Camera, Sorry...But In Realaty You Can See It Clearly. Will I Be Able To Change That Part Of The Laptop By Sending It To ASUS? And Also I There Is Another Colour Change On The Lid Of The Laptop...Its Slightly Whiteish. So Will I Be Able To Change The Color Change By Sending It To ASUS?
Do you mean the illumination of the power symbol on the power button? If so, then the short answer is no, the slightly longer answer would be to just put some tape over it, the longer answer still would be it would require some warranty voiding and likely collateral damage causing modifications to the palm rest.
