It's been a number of weeks now and this is still happening. I've read some other threads on this forum and tried quite a few things:
- Uninstalled Instant On
- Uninstalled Power4Gear
- ASUS LiveUpdate
- Tried not using any USB ports
None of these things have worked.
I've also noticed some really high speed fans coming on and going off both when plugged in and when on battery only (but the shutdowns only happen on battery only) so I ran some monitoring using HWiNFO64 and attached the results. These temps seem high to me since I was only using word docs and Chrome during this time and not gaming at all. Thoughts on those temps?
Also, I did some monitoring of my battery using BatteryInfoView and it looks like the wear level is down to 43%. I've attached those results as well.
So I guess my questions are:
- What are some thoughts on my temps?
- Should I repaste my CPU?
- Could a low battery capacity ALONE be causing these shutdowns and high temps or is that a EVIDENCE of another problem?
Thanks a ton for any help!
