G752VY max gpu fan speed ?
CerealKillerGuy
I just noticed that my gpu max fan speed is only 3600rpm while the cpu one goes up to 4100.
Can you guys tell me what max rpm's you get on the gpu fan?
Thank you!
10 REPLIES 10
You should read Dreamonic post he discussed that the fact that some G752 heat sinks were not setting level on both CUP and GPU, his solution is to carefully bend the heat pipes until the CPU and GPU sit flat 100% contact with the heat sink. He claimed -10C on all that he had done this with. You may want to discuss this with him for further information.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
