04-13-2017
09:12 AM
- last edited on
03-05-2024
10:34 PM
by
ROGBot
04-13-2017 10:04 AM
04-13-2017 11:05 AM
cl-Albert wrote:
Welcome to the forums!
I'm perplexed by it and not sure what is causing it, so feel free to ignore or disregard anything below if necessary since it may be incorrect.
- If somebody hasn't already, make sure the replacement adapter specs matches the label under your notebook which should be something like 19.5V, 11.8A, for 230W. Sounds a little unusual, but if the replacement adapter did solve the problem at first, wish there was an easy way to check it on another system or try another charger just to make sure that one didn't happen to go bad too (what are the chances?).
- Assuming the charger is okay, seems unusual to me that there would be any problem with the DC jack if you don't see anything loose or wrong on your end, but I don't work in repair and have much experience with it either.
- Not sure if it's worth the trouble or what it would tell us, but I believe the unit should run fine on AC power without the battery (again haven't tried it myself), so you might try removing the battery and maybe booting into the bios so it doesn't cause any problems with Windows or your hard drive if it unexpectedly powers off (might want to remove your hard drive too?) just to see if you can get it to power off by wiggling the jack, etc. and confirm there is really some problem with it or not.
- If everything is fine without the battery, it may not be easy to check without a spare battery, but wondering if there could be a battery issue although don't think I've ever run across a battery that just charges intermittently (I don't work in repair either though)
- So if it's not the adapter, the DC jack, or the battery, wonder if there could be something with the motherboard battery charging circuitry, but not easy to check without another motherboard, so you may just need to check what you can before getting to this point.
Also, if you didn't already know, the system doesn't always charge the battery when the charge is above 95%, so just want to confirm the battery charging issues are below 95% charge.
Feel free to discuss or request more suggestions from others and good luck!
04-13-2017 01:44 PM
Furmentor wrote:
Removing the battery on this thing is quite the chore (need to remove MB), but since it is currently disassembled, I could reassemble it without the battery and see
what happens.
Furmentor wrote:
If the motherboard circuitry is going bad...well that is a problem. Is that something I would need to send to Asus? I don't think a general computer repair shop could handle that.
Furmentor wrote:
In response to the 95% charge issue, charging is intermittent. It's drained the battery and would not charge. come back the next day. plug it in and it charges again. That being said, I only really use this computer when it is plugged in since it is really only for gaming. When it is unplugged I only get about half the performance.
04-13-2017 07:28 PM
