G751JL - How does the cooling system work?
kyleireland
I've been wondering. How does the cooling system on the G751JL work? Are there only outtake fans on the back?
Thanks in advance.
XOIIO
Yes, just outtake fans, they pull it through the bottom/middle. You can find teardown images to see what the heatsink design looks like.
clockworksatan
It pulls air in through the ports on the side and the keyboard at quite an impressive rate. If you hold a bit of tissue paper to the ports on the side while the fans are going you can see it being pulled in. I think it also draws air in from the keyboard too.
Asus ROG G751JT-T7115H
17.3" IPS, Intel i7-4720HQ, 16Gb RAM, NVidia GeForce GTX970m, 256Gb M.2 SSD + 1Tb SSHD
