G751J Battery not charging and sudden shutdowns
Elharawy
Hello everyone,
I have had MY ROG G 751J for almost 14 months now, it was acting great.
2 days ago i have noticed that my battery is stuck at 0% although indicating that its plugged in and charging (attached image)
then the laptop suddenly shutdown completely. I re-opened the laptop worked fine till after i logged into the Windows then it shut down again, kept on repeating the same process 6 - 8 times unfortunately same result.
I restated the laptop and signed in with the safe mode ( works fine ) i backed up my recent data and restored the windows back to factory settings and installed all drivers and updates, after restoration it worked fine, yet with the same battery problem. then i turned it off and went out, 5 hours later i came back home tried to use the laptop, but the same issue happened again .
The battery ins't charging ( laptop on and off)
I am not quite sure what might be the problem , so if any one could help that would be great. Thank you
[Update]
The laptop doesn't shutdown anymore, yet the battery LED blinks orange and the battery status changed to " 0% plugged in NOT charging" Does it mean a dead battery?
19 REPLIES 19
Well if your going that far, why not just change out the batteries and put some new ones in before you close up?
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
I now have a total of 5 (yep, five -- four working and one not) Asus ROG G751JT laptops in the family, and the first one we bought for my son started having battery problems after a little under a year. I did some troubleshooting with the help of Asus support and determined it was a problem with the charging circuit on the motherboard, so I RMA'd it to Asus under warranty (which still cost a fortune). They did fix it, but then just a few months later, a cell in the battery failed (no, the b@astards didn't replace the battery when they were in there replacing the motherboard). So I bought a 3rd-party battery on Ebay and replaced the failing one. The battery would charge up fine, but when I tried to run the laptop off the battery, it would abruptly shut down and would only stay on while plugged into AC power. Given that the battery charged up to 100% fine, I assumed it was another problem with the power circuit on the motherboard, but it was already beyond their 90-day warranty on the original warranty repair, plus I didn't want to spend another $200 shipping it back to Asus. So I just shelved it and bought another one (easily moving the hard drive over) and got the poor boy back up and running. When my other son's ROG screen cracked (closed it without realizing something was on the keyboard), I cannibalized the shelved ROG to replace that screen.
So, I recently took our "parts" ROG off the shelf, replaced the LCD and decided to try another battery (3rd-party but from a different source), and this busted up ROG is back to running like new, runs off the battery just fine, screen looks beautiful, etc. The moral to this story is if after replacing the battery your laptop still doesn't work (at least not properly), then it could still be a battery issue and you should probably try another battery. The 3rd-party batteries have questionable reliability, but if you get one that works after swapping it out, it will most likely stay working fine. I was going to use this ROG (working battery or not) as a security camera DVR, but now that I have it working perfectly again, I'm just going to keep it around as a backup for when/if any of the other ROGs fail (it's so easy to just swap out the hard drives).
Replacing the battery isn't that difficult. You do not have to remove the motherboard. If you have a very thin shaft phillips head screw driver, you can even remove and reinstall the two screws on the battery without removing the screen/hinges/etc. (which is great because reinstalling those wifi wires on the motherboard is a tedious pain!). Once you have the two screws out of the battery, just use a flathead screwdriver to carefully flex the bottom/back of the casing out and then use another flathead to pry the battery out. You're just looking to get the battery out over those four locking tabs. Just be careful how much force you use so you don't crack or otherwise damage the laptop casing.
The LCD is even easier to replace than the battery. On YouTube there is a really good tutorial on the whole process for a G750 series -- don't follow that! It's very different from the G751 series laptop, and on the G751 you literally only have to remove ~8 screws (4 on the bottom edge of the screen casing and then 4 more on the inside that holds the LCD into the frame). There's one main ribbon cable and a very small ribbon cable for the camera.
The replacement LCD was $100 and the battery was $55. That's cheaper than shipping to Asus for a warranty repair.
whoa :eek:
but where, dear sir? where did you get the parts for that price?
no siggy, saw stuff that made me sad.
haihane wrote:
whoa :eek:
Sorry about that -- I'm usually better about posting links. Honestly I was just way too excited to finally be approved to post here after waiting literally for 1.5 years. Not kidding.
Anywho...
Amazon!
Battery:
https://www.amazon.com/gp/product/B06XD7K4SX/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
LCD:
https://www.amazon.com/gp/product/B018O8DN4E/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Same problem, if anyone hasn't bought a ROG yet - just pretend it has no battery. The battery is totally useless, if you pretend it never had one in the first place like a desktop then it will annoy you less. That is basically what I have to do now, it may as well not have a battery at all.
No friend, the problem is that most ROGs dont work at all without battery.
Crazy architecture, it needs battery power too, to operate.
haihane
thank you! this might come in handy one day, and i'll know where to find 'em, thanks to you.
Om3N20
Hi every 1. My laptop start having the same battery problem I guess it's dead. I can turn on but it will off after few minutes. The problem now is the battery share by internetpilot from Amazon it's not sending to singapore... any 1 from singapore have idea to buy?
I Just ordered my replacement battery for my 751JT from AliExpress - $38 (plus the obligatory China import tax - oh well, im fed up waiting forever with a dead ROG). Will let you know when it arrives how it goes -
https://www.aliexpress.com/item/OEM-A42N1403-Battery-for-ASUS-ROG-G751-G751JT-A42LM93-4ICR19-66-2-GF...
Cheers
yeatsie
Exact same thing happened to my ROG 751JT 5 months ago, flying over going through airport security scanning - must have been the last straw for the battery.
Now i turn it on while plugged in (Windows 8.1), it stays on for about 20 seconds, then shuts down again. Repeat about 10 times, then sometimes, it stays on for a few hours - its almost like it needs to get enough residual charge in there somewhere, to prevent it shutting down again, until i presume all power is removed again, and the whole shenanigans repeats again.
Thanks Internetpilot for your info on replacing the batttery in situ - i've just ordered a replacement battery from AliExpress (im in Cyprus now) and i will try your tips on removing the battery hopefully without having to micro-disassemble the entire laptop (which some of the online videos seem to prefer)
Will keep you posted when/if it arrives and i can get this ROG back on its feet..
