G751 Imbalanced Sound Problem (internal speakers only), FIX IS OUT!
Jlieu
http://support.asus.com/Download.aspx?SLanguage=en&m=Audio&os=30
download the latest Version V6.0.1.7427
No new UI as promised. lol
Edit by cl-Albert: Hope it's okay to edit your post Jlieu, but anybody that wants to read more about the original problem and gory history of this issue may want to check this post below which is currently closed while we check out this new *.7432 G751 audio driver version at this post. Thanks.
G751 Imbalanced Sound Problem OFFICIAL SUPPORT THREAD
https://rog.asus.com/forum/showthread.php?54313-G751-Imbalanced-Sound-Problem-OFFICIAL-SUPPORT-THREA...
412 REPLIES 412
benjmyers1
Latest driver (6.0.1.7673) (with sub at 50%) is the BEST driver i've used for sound. I haven't had to do any tweaks or reg edits either, just lowered sub to 50%
http://dlcdnet.asus.com/pub/ASUS/nb/DriversForWin10/Audio/Audio_Realtek_Win10_64_VER6017673.zip
Thank you benjmyers1 .... This is the BEST BEST BEST audio driver for G751JT......subwoofer 60 and ALL sound is AMEZING..... .Realtek good work finally.... I have amazing sound after 1 year when I bought pc 🙂
no problem
Hello viper just asking can tell me step by step on how to install the driver thanks a alot
How do you guys deal with the constant buzzing from the speakers? I am pretty sure it's hardware related, but is there some kind of cure for it, or i just have to live with it?
I get it when the maxxleveler or maxxvolume are enabled, without them there is none, but the volume is super low especially in a noisy environment.
My subwoofer is at 20 and hear it even from the L and R speakers.
Installation fails on G751JY with a strange Error.
I've read here many suggest how to configure EQ etc. in the Realtek panel... IMHO it's wrong. Ignore that. The best audio results come from MaxxAudio fine-tuning. I suggest in particular the profile "Action" and something like this:
55030
// ASUS SCAR18 G834JY, i9-13980HX, 4090 laptop 256bit 16GB, 32GB 5600MHz RAM, 18'' 16:10 2560x1600 240Hz G-Sync internal screen, external UWQHD 3440x1440 Mi 34'' Monitor with Freesync, NVMe, 8BitDo Arcade Stick, Vader 4 Pro controller, ROG Strix Carry mouse.
55030
This is the only setting you use?
On the sound settings, you leave everything default like subwoofer at100%?
Thanks in advance
Yes, don't touch other settings (Realtek panel or Windows EQ). I've found it gives the best results.
Where can I find the MaxxAudio software ? I'm on Windows 10 and I can't seem to find it anywhere.
It's part of Realtek for ASUS drivers. Probably not present with the std Realtek drivers package for everybody.
It's present here for example: http://www.asus.com/ROG-Republic-Of-Gamers/ROG-G751JY/HelpDesk_Download/
