G751 Imbalanced Sound Problem (internal speakers only), FIX IS OUT!
Jlieu
http://support.asus.com/Download.aspx?SLanguage=en&m=Audio&os=30
download the latest Version V6.0.1.7427
No new UI as promised. lol
Edit by cl-Albert: Hope it's okay to edit your post Jlieu, but anybody that wants to read more about the original problem and gory history of this issue may want to check this post below which is currently closed while we check out this new *.7432 G751 audio driver version at this post. Thanks.
G751 Imbalanced Sound Problem OFFICIAL SUPPORT THREAD
https://rog.asus.com/forum/showthread.php?54313-G751-Imbalanced-Sound-Problem-OFFICIAL-SUPPORT-THREA...
412 REPLIES 412
Ivan_Palic
I got my machine back from repair shop. They replaced speakers and now it has proper sound. 🙂
What was the issue ? the speaker turning off and on or other problem ?
No, the problem was I only got sound from subwoofer, the other two speakers didn't produce any sound whatsoever. I have tried all drivers available and all the settings, but nothing changed, so I had to send it to repair shop. They replaced the speakers and now everything is working just fine.
x7007
yeah, i'm using 7560, and it sounds good.
CoolerMaster Maker 5T - ASUS CROSSHAIR VIII EXTREME - 65-inch UHD 4k SAMSUNG Q8FN - AMD Ryzen 9 5900X - NZXT Kraken X72 - 10 SIRIUS LOOP/NZXT RGB Case Fans W/ HUE+ - Gigabyte AORUS 1080 TI EXTREME - 64GB GSkill TRIDENTZ NEO 3600Mhz DDR4 - 3X XPG GAMMIX S70 2TB NVMe SSD'S- 2X CORSAIR FORCE MP600 NVMe SSD'S - WD BLUE 8TB HDD - Logitech wireless KRAFT advanced keyboard - Logitech M570 wireless trackball - Dual booting WIN 11
x7007 wrote:
new drivers seems whql with maxxaudio support 7560
ftp://ftp3.realtek.com.tw/Realtek/7560_PG431_VISTA_WHQL_DellSkylake_SST_v503_WOV_v84_USBAudrd_v33_Ma...
WOW, 400+ MB for an audio driver!!!
Is there a "lighter" version around?
benjmyers1
whats the user name and password?
I have used this.... (because man x7007 forgot add this information)
login : spcust
password : hwwk758z
login : spcust
password : hwwk758z
I have trtied driver 7560 but it isn't good driver ....(rattle sound).....:(
aeolisio
I have already changed over 14 g751s from work to the 7560 all without problems. I have seen 2 g751s where one of the speakers physically was loose and rattling around have you removed the back cover and checked them? Its only a few screws on the top when its flipped over. I only noticed because i was pulling the stock speakers for those units and installing bose speakers for upgraded sound quality.
3d printed parts and accessories for the G751. You know you want something better than OEM ->https://www.shapeways.com/shops/aeolisio[SIGPIC][/SIGPIC]
