G751 Imbalanced Sound Problem (internal speakers only), FIX IS OUT!
Jlieu
http://support.asus.com/Download.aspx?SLanguage=en&m=Audio&os=30
download the latest Version V6.0.1.7427
No new UI as promised. lol
Edit by cl-Albert: Hope it's okay to edit your post Jlieu, but anybody that wants to read more about the original problem and gory history of this issue may want to check this post below which is currently closed while we check out this new *.7432 G751 audio driver version at this post. Thanks.
G751 Imbalanced Sound Problem OFFICIAL SUPPORT THREAD
https://rog.asus.com/forum/showthread.php?54313-G751-Imbalanced-Sound-Problem-OFFICIAL-SUPPORT-THREA...
412 REPLIES 412
Paco wrote:
did everything like you said ...... and still no Audio Wizard.
Paco, did you do a search for the MaxxAudio app?
If it doesn't show up in the tab within the Realtek HD Audio Manager, look for it as a shortcut on your desktop, or hunt it down in the folder it lives in: "C:\Program Files\Waves\MaxxAudio\MaxxAudioControl64.exe"
After you run it for the first time, see if it now shows up in the Realtek HD Audio Manager.
There was a problem with the MaxxAudio not being installed with some driver installs long ago (before the G751)...but if everyone else is seeing MaxxAudio with 7432 and you aren't, then I would reload your OS - F9 reset - and start again, something might have gotten messed up if you were installing/uninstalling lots of driver versions trying to get it to work leading up to the new 7432 driver.
Please come back and let us know what works for you 🙂
Jlieu
I have audiowizard comes along.
NitroX
These new drivers really make a big difference. The sound is more balanced and with the MaxxVolume and MaxxLeveler activated on Multimedia Settings, it can go up to 100% without big distorsions (with the MaxxTreble and MaxxBass at 0). Now, I think the sound is even are even better than the one on G75VW.
I will also test how the new drivers perform with an external 5.1 System and come back with the feedback. I own a Logitech G51 that misses the 5.1 surround due to lack of driver support -_- ... It's good that they have the internal 5.1 virtual surround, but that tends to get messy on the rear speakers.
Rares95
I don't see any new UI on the V6.0.1.7432
Download the new drivers, extract them and click on the setup. Next just follow the steps and when it ask for restart just click ok. It will ask you twice to restart your laptop (once for completely uninstalling the old drivers and one for completely installing the new drivers). The first time I installed them I clicked cancel when they asked for restart and the wizard didn't complet the install so I didn't get the AudioWizard at the end. Just follow the instructions as intended and everything will be ok. You GOT to try these new drivers... they are awesome even for the 5.1 System. It can boost it's treble and bass very much, and now it works on real 5.1 surround which will be a pleasure for movies :D.
I have the JT laptop but downloaded the new JY audio dive and it works. Sounds amazing. I'm not sure what to chose for the Audio Wizard. I like how Action sounds. But I afraid to push my speakers. Hopefully people will start to figure out the best presets and post them here.
will Audio Driver Version V6.0.1.7432 work on all g751 series say perhaps the jt?????
yes
Hello,
I'm now testing the 7432 drivers. This works very well. The sound is very nice.
Thank you to all who have contributed to advancing the solution since the first discuss about "Imbalanced G751 Sound Problem" (.http://rog.asus.com/forum/showthread.php?54313-G751-Imbalanced-Sound-Problem-OFFICIAL-SUPPORT-THREAD...
greetings,
_ATOM
TRY THIS !!
at first : sorry for my bad english , i hope you unterstand, iam from Germany 🙂
i have the same Notebook with the same Sound Problems , but yesterday i tryed the V6.0.1.7576 Driver for Win10.
I have Windows 8.1 on my Notebook but it works well with this Win10 Driver. I think this is the best way to get good Sound at the moment!
You can use this Driver with Win 8.1 and Win10.. Works well..
Direkt Link for the Driver :
http://dlcdnet.asus.com/pub/ASUS/nb/G751JT/Audio_Realtek_Win10_64_VER6017576.zip
but before installing, go to your Device Manager and reinstall your old Driver and then install this new Driver.
