G751 Imbalanced Sound Problem (internal speakers only), FIX IS OUT!
Jlieu
http://support.asus.com/Download.aspx?SLanguage=en&m=Audio&os=30
download the latest Version V6.0.1.7427
No new UI as promised. lol
Edit by cl-Albert: Hope it's okay to edit your post Jlieu, but anybody that wants to read more about the original problem and gory history of this issue may want to check this post below which is currently closed while we check out this new *.7432 G751 audio driver version at this post. Thanks.
G751 Imbalanced Sound Problem OFFICIAL SUPPORT THREAD
https://rog.asus.com/forum/showthread.php?54313-G751-Imbalanced-Sound-Problem-OFFICIAL-SUPPORT-THREA...
412 REPLIES 412
aeolisio wrote:
I have already changed over 14 g751s from work to the 7560 all without problems. I have seen 2 g751s where one of the speakers physically was loose and rattling around have you removed the back cover and checked them? Its only a few screws on the top when its flipped over. I only noticed because i was pulling the stock speakers for those units and installing bose speakers for upgraded sound quality.
Hi, could you link me the site where to buy those Bose speakers via PM?
Do they sound much better than the stock ones? Is it difficult to replace them?
Could i also have the link and details please....sounds like an interesting idea
Nemix
Realtek HD Audio Driver 6.0.1.7564 (WHQL) for Windows 7/8/8.1/10:
ftp://spcust:hwwk758z@ftp3.realtek.com.tw/Realtek/GeneralRelease/7564_PG431_Win10_Win8.1_Win8_Win7_W...
***Realtek HD Audio Driver 6.0.1.7569 (WHQL) for Windows 7 & 10 Only:
ftp://spcust:hwwk758z@ftp3.realtek.com.tw/Realtek/WHQLed_DRV/7569_PG432_Win10_Win7_WHQL.zip
nice but if anyone wants the maxx audio wizard
you just go to http://support.asus.com/Download.asp...udio&p=3&s=111
click windows 8.1x64
download this
Version V6.0.1.7503
Description Realtek Audio Driver
or any realtek audio driver more current then that but thats the one i used. it will reboot you 3 times for install and youll have the rog audio wizard again.
3d printed parts and accessories for the G751. You know you want something better than OEM ->https://www.shapeways.com/shops/aeolisio[SIGPIC][/SIGPIC]
r_k_y
hey guys i tried 6.0.1.7503 driver all speakers works fine, except from the internal bass(speaker on below of laptop), it vibrate like crazy when i turn the sound higher using microsoft volume slider( standard volume slider) did any of you guys are having same problem with me? is this hardware or software probs?
*i have tried a few driver from realtek(7560,7569) also having thr same issues
thanks
diogogmaio
Yeah. can someone post how to change the speakers and what speakers to replace?
Other thing could be posting only how to open until we reach speakers to check the connection...
Please reply and thanks
noralain
hi guys,
I was about to return my laptop so they can fix it, I thought hardware issue, but after reading your posts, I upgrade my driver to latest from asus website I got control over internal subwoofer and changed it to 20%. but this is not fix actually.
I lost the GUI sound managment because I completely uninstall and installed latest version
and the issue is not 100% fix. 😞
do you think it's good idea to just return it and let asus office do something with it ?
rogdood
I don't think there's a real solution to this. Having tried more than 10 driver versions, I still get popping and crackling, mostly audible when on youtube or movies, in between scenes, when it's less action packed.
It's ridiculous how they can't even make the damn sound system work like a cheap Chinese music player can.
A temporary solution is this: https://rog.asus.com/forum/showthread.php?54290-I-have-crackling-sound-with-g751JY-PLEASE-HELP!&p=49...
Still, it does not remove crackling for a long time, for me it seems to have returned back to it's crackling state after 5 mins.
The complete 100% workaround for crackling is here:
Just install and enjoy...
More info here: https://rog.asus.com/forum/showthread.php?60761-G751-Sound-Crackling-Thread-(The-one-thread-to-rule-...
x7007
I messed up something in my windows 8.1 x64 with Maxxaudio
I installed 7576_PG433_Win10_Win8.1_Win8_Win7_WHQL_USBAud_33_With_MaxxAudio_Installer_MUP
Which is a Dell version and I don't have Maxxaudio anymore, can anyone tell me how to restore it ? when I try to run the Maxxaudio.exe file it opens me a blank empty windows , when I try to open MaxxAudioMeters64.exe, it shows me Dell Audio with 2 bars and I can't change anything. I don't know how to get rid of it, I tried 5 old versions, I tried uninstalling it in different ways. I can't do Restore Last settings in windows because it was disabled .
EDIT : P{FFFFFFFFFF the problem was using the https://rog.asus.com/forum/attachment.php?attachmentid=48737&d=1430253959 from the thread G751 Sound Crackling Thread (The one thread to rule them all) [WORKAROUND]
and the service just ****ed it up. I uninstalled the service option 2 and I got the AudioWizard back.... ffs I never install anything like that anymore, more than 30 restarts till I thought this called be a problem.
