G751 Imbalanced Sound Problem (internal speakers only), FIX IS OUT!
Jlieu
http://support.asus.com/Download.aspx?SLanguage=en&m=Audio&os=30
download the latest Version V6.0.1.7427
No new UI as promised. lol
Edit by cl-Albert: Hope it's okay to edit your post Jlieu, but anybody that wants to read more about the original problem and gory history of this issue may want to check this post below which is currently closed while we check out this new *.7432 G751 audio driver version at this post. Thanks.
G751 Imbalanced Sound Problem OFFICIAL SUPPORT THREAD
https://rog.asus.com/forum/showthread.php?54313-G751-Imbalanced-Sound-Problem-OFFICIAL-SUPPORT-THREA...
412 REPLIES 412
I managed to minimize this issue in my G751JT by installing Realtek High Definition Audio(HDA) R2.8x (7701) WHQL + Dolby posted by kingjezdi.
You also want to set 500Hz band in your EQ as low as possible. In my case, it causes vibration on my touchpad button.
Thana_Toast
Any updates?
Started getting this issue regardless of the driver I'm using on my GL551JW, even when I fully uninstall the driver back to the default windows one.
The only fix I've found is going into my balance settings, putting it at max volume then putting balance fully to the left then full balance to the right and
then putting balance into the middle. Even after doing this within the next few minutes my right internal speaker will dip to be 20% volume of what my
left speaker is and I'll have to repeat the process. I'm still under warranty until August.
Hello and sorry for my english but i am french
I have bought a refurbished G751JT and i have the same problem.
I have try every i know and every i found on the Internet to solve my problem but i have always it.
I have sound on the Left and on the Sub (And on the sub a very poor sound)
I have check my right speaker and it is not a harware problem only software like you.
Can u give me a issue please? I am desperate lol.
I tried old drivers, new drivers, last drivers and unofficial drivers without succes.
Please help me 🙂
Thanks U
Best Regard
Sylvain
Mousepad
xposting this from sound crackling thread - I recently installed Windows 10 and the driver it comes with for my G751JT is 7543 and it is horrible. Listening to people talk on youtube at volume level 40 has so much shrieking, distortion, etc. I found 7701 on the G751JL page and it works really well. http://www.asus.com/ROG-Republic-Of-...Desk_Download/
I also did the regedit trick and put maxxaudio on "action" and the sound is much, much better. Just FYI if anyone has the same issue with windows 10.
It is a little better for sure.
But the distortion and everything else is still there. We cannot outrun that sadly.
I am also with regedit, action (default) and 7701.
How about windows sound levels? realtek setting? Have you changed anything? Like internal subwoofer level?
Let me know and thanks.
I left windows sound levels and realtek settings at default.
Just downloadet the newst 7836.
And finally there is no crackling issues anymore.
EDIT: ok... there is still a little issue. But much better for my opinion.
Can you please give us a link with the driver ? Because I couldn`t find it on the asus website...
Thank you
Thank you
https://drivers.windows10download.com/w10-realtek-high-definition-audio-driver-6-0-1-7836-for-window...
The thing is that the sound it`s fine if I turn Maxaudio off....but without max audio you can t really bennefit from that subwoofer....it s so frustrating...
