G751 Imbalanced Sound Problem (internal speakers only), FIX IS OUT!
Jlieu
http://support.asus.com/Download.aspx?SLanguage=en&m=Audio&os=30
download the latest Version V6.0.1.7427
No new UI as promised. lol
Edit by cl-Albert: Hope it's okay to edit your post Jlieu, but anybody that wants to read more about the original problem and gory history of this issue may want to check this post below which is currently closed while we check out this new *.7432 G751 audio driver version at this post. Thanks.
G751 Imbalanced Sound Problem OFFICIAL SUPPORT THREAD
https://rog.asus.com/forum/showthread.php?54313-G751-Imbalanced-Sound-Problem-OFFICIAL-SUPPORT-THREA...
412 REPLIES 412
cip_bleah
Setoku, what were the problems you were having, because it sounds the same as the 7432 version.
There is still the click when opening an audio program, and the sub is.. just listen to the sub alone to see if it is sounding clean.
We can at least silence the sub and it is clean.
cip_bleah these are my settings and i have good sound keep in mind i have to set my audio to 5.1 for shadowplay
48522
The driver version i have is 7469
the things i would experience are crackling poping sounds stuttering that was very bad on battery when set to powersave mode but this seems to have fixed all my problems I've had
Also one thing if you want to try my set up make sure you put the EQ to shooting :cool:
Keep in mind the setting is not ideal for the average user you wont notice anything from your sub on 5.1-Not sure why shadow play records good on this sound setting but it works.
Sanctrum
Setoku, you have quite bizzare configuration 🙂
diogogmaio
Yes quite bizarre. Someone can share other configurations too? Is 5.1 without maxx audio better than 2.1 with maxx audio?
Setoku
This is my setup for stereo still the eq is set to shooting not much has changed i dont use max audio eq as it just makes everything sound bad the realtek one is better haha
48528
Feel free to share yours i know mines not the best but it works 😄
diogogmaio wrote:
yeah i'm trying to lower a bit the sub...but tell me something... do you have that realtek configuration AND the maxx audio settings that u display in the image? or you only have the realtek settings and the maxx audio off? Maxx audio off puts the sound very low
48528
Thats my setup for the 2 speakers
diogogmaio wrote:
Also shadowplay cannot record from stereo? why? sorry to ask
Not sure shadowplay is still in beta if it could just record to wave it wouldn't matter what the speakers settings are but it doesn't let you choose yet
Cant say why shadow play doesn't like the sound on this laptp
diogogmaio
i cant decide whats better...stereo or 5.1...
i mean for music, series and movies...also gaming... your settings sounds nice...i tried them...only a bit distortion coming from the subwoofer,,,almost perfect...
So stereo or 5.1? Anyone else wants to share the set up
Setoku
diogogmaio
Stereo is very good i only use 5.1 for shadowplay but things i have noticed with 5.1 are its more clear but then you don't really get the sub
try playing around with it until the distortion goes away
diogogmaio
