09-03-2015 04:01 PM - last edited on 03-05-2024 08:19 PM by ROGBot
09-04-2015 09:26 AM
Edweird wrote:
I'll just add my 2 cents here.
Many model/fighting lightsaber builders like UltraSabers and Saberforge as well as others use only the Panasonic and Trustfire batteries with Panasonic apparently being the best of them all.
I don't know about Ultrafire vs Trustfire but I can confirm that Panasonic 18650 ones are very reliable - I've been using them for years for things like aforementioned lightsabers and flashlights. (The NCR18650B 3400MAh 3.7v ones.)
You can get 2 for $14 atm. I was actually quite surprised to see that kind of capacity at that voltage considering the size of the things.
09-05-2015 02:29 PM
09-06-2015 02:37 PM
09-07-2015 10:55 AM
TheWitcher wrote:
Your always working on something to make the g751 better. What other things are you thinking up? Is there a way you could make the g751 battery removeable without taking out screws? Or could you make a second battery pack to carry around like those battery banks for cellphones but bigger?
09-14-2015 12:27 AM
09-15-2015 03:16 PM
TheWitcher wrote:
I wouldnt mind the weight it would be nice to have an option like removable batteries for when i cant get to an outlet. I would want to keep close to the same size though. Would i have to send you the entire laptop for you to make the battery removeable. or would a better choice be to make the pack with removeable cells. i have a nice 18650 charger and then i could jus change the batteries myself.
09-21-2015 02:52 AM
aeolisio wrote:
I would only need the battery itself if your goal was modifying the case or installing a 3d printed bottom cover yourself. The pack has very little room so if you wanted an easily removable individual cell option i would suggest a 3d printed battery case aswell to give extra room for the springs. You might consider just an add on bank of batteries and wire it in to the current battery with a removeable plug that way you could use the same charge circuit and it would just read as an increased mah and charge for longer. Thats easier than carrying a seperate charger or a handful of seperate batteries. There are too many options to list it really comes down to what you need from it. How much extra charge do you need how much weight can you add and how comfortable are you with modding.
09-21-2015 09:47 PM
TheWitcher wrote:
I like the idea of a bank of batteries as an add on so i only have to bring it when i need it. Could you make it mouse pad size and put some material on it so it can double as a mousepad. or could you add it to my cooling pad stand?
09-18-2015 04:28 AM
09-18-2015 03:48 PM
Pandora\'s Box wrote:
i rather have no battery and save weight everywhere i go has a plug
