06-12-2017 10:25 AM
06-19-2017 09:23 AM
06-19-2017 09:56 AM
cl-Albert wrote:
You may want to check around for more ideas, but unfortunately, sounds like a hardware problem to me, or at least replacing the defective hardware should be able to solve the problem.
Not sure if you will be able to find any solutions without replacing the hardware.
If it helps, you can try to set the Windows battery warning level to something higher like 40-45% to remind you that the system will be powering off soon and hopefully avoid any unexpected power-offs, but not sure how well it will work or how long.
06-19-2017 01:42 PM
09-13-2017 12:45 AM
cl-Albert wrote:
If you still have warranty for the rest of the unit, you may want to check around more if you prefer, and if you haven't discussed with your local ASUS support consider discussing with them as well
https://www.asus.com/support/CallUs
I don't work in repair, so could be wrong, but guessing it is just a bad battery that needs to be replaced although in rare cases, there could be problems with both the battery and motherboard.
09-13-2017 04:26 PM
