G46VW Cooler always running at maximum speed
Wonder
Few days ago I got critical windows 8 error: DPC WATCHDOG VIOLATION.
After that, I noticed that cooler always running at maximum speed, no matter what temperature is, is it plugged or not.
Computer model: ASUS G46V (G46VW).
Any thoughts?
4 REPLIES 4
HiVizMan
Level 40
Have moved your thread to the laptop section maybe someone there can help you. 🙂
Clintlgm
Level 14
Yep what are you temps CPU GPU, my guess is that one or the other is very high causing your Fan to try to cool it off. If your in warranty RMA if not Repaste
You can use Hwinfo64 to check what your temps are
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
Wonder
Now I noticed that notebook doen't see Nvidia graphic card at all, it uses only integrated one.
You don't have an integrated one, the Intel built into your CPU is disabled, so you are running the generic MS Video software. Install the latest posted video drivers posted on Asus Support Downloads
You still haven't let us know what your GPU and CPU Temps are? Mother Board controls fan speeds, as temperature rise the fans spin faster.
If you are having excessive temps and you continue to use your Note Book you are going to damage more parts
980m GTX 4 GB
Windows 10 Pro
Z97 -A
Windows 10 Pro
