Fan speed and cpu/gpu temperature
nagooro
Is there a way to increase the fan speed when gaming? And a way to see the cpu/gpu temps?
Thanks
HiVizMan
Level 40
Yes there is. You can use Afterburner to set up a profile or simply raise the default RPM of the fan.
GPUz has a monitoring tab that will allow you to see the temps and a heap more information.
Sorry, are these 3rd party programs I need to download?
Was under the impression fan speed was locked to the bios since that option isn't available in afterburner for me, neither does HWinfo allow me to set custom fan profiles.
