Cooling system problem - g73jw-a1
Andrew_85
Hello guys
It's been a month or so that the cooling system of my laptop is almost always on and sometime it become very noisy,what can I do about it?
Is there a way to clean it or is it because of some application?
Thanks
Asus G73jw-A1 - Crucial M4 128gb SSD - 14 Gb DDR3 RAM - Windows 7 Premium X64
8 REPLIES 8
xeromist
Yes, easiest way to clean it is to get a can of compressed air and blow it into the fans to break free and expel all of the collected dust.
Andrew_85
thanks .. but is it normal that the left cooling system it's way more hot then the right one??
xeromist
That's not uncommon. I'm not sure if you're referring to the vent or the laptop itself feeling hot but due to the location of components the temperature won't be even.
Andrew_85
I'm talking about the vent,the left side it's always way more hot then the right one . .is it normal to have the cpu almost all the time up to 96 C???and I'm not even turning on the turbo mode or playing games,just surfing . .
xeromist
No, 96C is not normal for idle. Either that reading is false or something is wrong. Is this the temperature after cleaning?
I didn't clean it yet because I don't know how to do it 🙂
in any case i noticed that the cpu is very hot when both the turbo mode and the intel turbo are on,but when they're both off it looks normal,around 70 . . .can the turbo mode be the problem?
JRd1st
Level 12
Isn't the CPU supposed to throttle when it reaches 70C?
Read the User's Manual for more info. 😄
G74SX-A1 BIOS 203
Intel 6230 WiFi/BT
LG E2350 LED LCD Monitor
Intel Series 510 120 GB SSD
Drivers, Apps and How To's
Latest nVidia Drivers
JRd1st on DeviantArt.com
JRd1st
Level 12
You mean 70c ideling? That's hot!
Use compressed air or canned air like Dust-Off and blow a bunch of short bursts into the vents and into the air intakes, too.
G74SX-A1 BIOS 203
Intel 6230 WiFi/BT
