Backtracker - possible to perform 2 operations using same usb device?
neverdone-_-
can i backup the factory recovery image & the ASUS Driver/App on the same usb? or do i need 2 usb drives?
sideshow_bob
YEs, you can
Prostar_Compute
As long as the drive is big enough, sure.
We customize Asus, MSI, and Clevo laptops!
Just be advised that all 32 GB and larger are not equal. Some can not be made to be bootable this can be goggled.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
