Audio Jack problem
amitabhbansal
friends
yesterday when i try to plug the headphone in g750jx i was unable to plug in as something is interrupting it to going in, i try to watch what is in it but nothing found, i thought to visit the service center but Indian service center are total crap, they will change the jack but spoil something else, so i decided to buy USB headset, there is Rog Orion Pro and Logitech G35 headset i found to use it by USB, i will never use audio jack, i will only use USB now, so please suggest me the better option between two of them or if any other headset is there pleae let me know,
Thanks
62 REPLIES 62
hmscott
Level 12
amitabhbansal wrote:
friends, yesterday when i try to plug the headphone in g750jx i was unable to plug in as something is interrupting it to going in, i try to watch what is in it but nothing found, i thought to visit the service center but Indian service center are total crap, they will change the jack but spoil something else, so i decided to buy USB headset, there is Rog Orion Pro and Logitech G35 headset i found to use it by USB, i will never use audio jack, i will only use USB now, so please suggest me the better option between two of them or if any other headset is there pleae let me know, Thanks
amitabhbansal, you could also go with the Sony Pulse Elite Edition USB dongle/Wireless. These sound awesome. The only drawback is only 5-6 hours of battery time before needing a recharge. Buy 2 and keep the other charging.
The bass is awesome, even without the Bass Impact boost, and gaming / movies sound great. They say Playstation 3, but they work great on my G750JH and PS4. If you reduce the Bass Impact you can extend the battery life.
Pulse Elite Edition Wireless Stereo Headset by Sony Computer Entertainment (Mac, PlayStation 3 / Vita, Sony PSP, Windows)
http://www.amazon.com/Edition-Wireless-Headset-PlayStation-3-63089006306200/dp/B0087OZ5FG/ref=pd_cp_...
Much better sound than BT headphones, but I still mostly use my Sony MDR-10RBT's because I switch between the G750 and Sony Z Ultra during the day, and I get 18+ hours use from them.
Sony MDR10RBT Bluetooth Wireless Headphones
http://www.amazon.com/Sony-MDR10RBT-Bluetooth-Wireless-Headphones/dp/B00FJISZ8M/ref=sr_1_cc_1?s=aps&...
I can also recommend the Sony MDR-1RBT headphones, but there is also a MKII version of those out now too - I haven't tried those. The originals got 20+ hours of run time.
SONY Wireless stereo headset MDR-1RBTMK2
http://www.amazon.com/SONY-Wireless-stereo-headset-MDR-1RBTMK2/dp/B00FJISZ0A/ref=sr_1_1?s=electronic...
Sony MDR1RBT Premium Bluetooth Over-the-Head Style Headphones (Black)
http://www.amazon.com/Sony-MDR1RBT-Premium-Bluetooth-Headphones/dp/B009A6D034/ref=sr_1_1?s=electroni...
Another thing to try is to push through the obstruction with a more narrow plug - like used with Toslink - the headphone jack doubles as a Toslink port. You would use an adapter like this:
CableWholesale Digital Optical Toslink Female/3.5mm Male Adapter (30F2-71200)
http://www.amazon.com/CableWholesale-Digital-Optical-Toslink-30F2-71200/dp/B000I97H54/ref=sr_1_10?s=...
If that fits, you can run a headphone amp, Receiver, DAC or other Toslink capable device - like my Sennheiser RS-220 headphones- to get audio out.
Let us know what you end up going with!
Thanks for the reply, i saw the headset and i like Pulse, but these all cant be ship to India, after a research i have ordered G35.
Lets see what happen
amitabhbansal, I haven't used the G35, but all my Logitech stuff has been great, so I am sure you will have a good experience with the G35 if it is compatible. Make sure you test it on Windows 8.1, some USB headsets work on Windows 8, but have problems on Windows 8.1 - so before your return period expires test it on Windows 8.1 on the G750.
Please come back and let us know how you like the G35!
amitabhbansal, bad news, there are lots of complaints about the G35 / 390 not working reliably on Windows 8.1 with USB 3.0
It may be related to USB 3.0 vs USB 2.0 ports, and the G750 only has USB 3.0 ports
http://www.logitech.com/en-us/support/g35-surround-sound-headset?section=downloads&bit=&osid=23&prev...
https://www.google.com/search?num=50&safe=off&q=logitech+g35+windows+8.1&oq=logitech+g35+windows+8.1
https://www.google.com/search?num=50&safe=off&q=2014+logitech+g35+windows+8.1&oq=2014+logitech+g35+w...
It looks like it isn't reliable on USB 3.0 + Windows 8.1...
Here is an older Steam post that might help if the newest unified driver won't work well, and the 64 bit ftp url still works, these are Windows 8.0/8.1 problems...
NASTY 7.1 AUDIO 100% WORKING FIX / WORKAROUND
http://steamcommunity.com/app/91310/discussions/0/828925216535994327/
Read the whole thread, there are multiple fixes as there are multiple problems; and likely lots more threads to read to catch all the options for fixes.
oh, I have read your posts and cancelled the order, now what to do?
amitabhbansal, if I was there I would start looking for new distributors inside India, to find a Sony, Sennheiser, or other dealer to import what I wanted - like the ones I mentioned - or other devices that are known to work with Windows 8.1. There must be a Sony India or Sennheiser India or some other wireless headphone maker importing to India - it is a popular product / need / desire.
And, I would go into your local India Asus Support center and explain the problem with the headphone jack, and try to get it fixed - without them messing up something else 🙂
And, you should know some people have issue with the headphone jack analog audio with low impedance headphones, like Apple earbuds, or other similar earbuds. You want wired headphones with 100-300ohm impedance to match the headphone amp in the G750.
I have paired other Bluetooth brands as well, like Plantronics - these the predecessors of these models that ship in the US:
Plantronics BackBeat GO 2 Bluetooth Wireless Stereo Earbuds with Charging Case - Retail Packaging - Black
http://www.amazon.com/Plantronics-BackBeat-GO-Bluetooth-Wireless/dp/B00DIOAM4Y/ref=sr_1_6?ie=UTF8&qi...
Plantronics Voyager 855 Bluetooth Headset (Black) - Stereo - image doesn't show 2nd wire/earbud
http://www.amazon.com/Plantronics-Voyager-855-Bluetooth-Headset/dp/B000UBNFT2/ref=sr_1_1?ie=UTF8&qid...
Here is a newer version I haven't tried, my old ones still work fine 🙂
Plantronics BackBeat 903+ Headset - Frustration Free Packaging
http://www.amazon.com/Plantronics-BackBeat-903-Headset-Packaging/dp/B00428N9OK/ref=dp_ob_title_def
If you want Wireless Gaming headset's there are quite a few more than the Sony's...
Call of Duty® Ghosts Ear Force Phantom Limited Edition Gaming Headset - these are good.
https://www.turtlebeach.com/product-detail/call-of-duty-headsets/call-of-duty-ghosts-phantom/394
I haven't tried these, but they are PC/Wireless/Surround sound:
Wireless 7.1 channel Dolby Surround Sound* audio with the Ear Force Z300
https://www.turtlebeach.com/product-detail/pc-headsets/ear-force-z300/369
Are there gaming specialty shops in India that you haven't tried that might carry something like these?
There are no good gaming shop, all which are here have low quality gaming headset because no one buy expensive headset, please tell me one headset 7.1 with brilliant voice, bass but it should be wired not wireless, i will see if i can find it in India. i like pulse but it is wireless and charging it is pain for me, searching for the dealer of it, waiting for your reply.
Thanks
(check ur private message)
amitabhbansal, I thought you wanted to avoid a wired headset? Did you get the headphone jack fixed? For a working USB solution you are going to have to find someone that has hooked it up with a USB 3.0 port and Windows 8.1 to make sure it is compatible / trouble-free.
Charging becomes 2nd nature, as I fall asleep I plug in half a dozen things to make sure they are all ready for when I wake up the next day 🙂
The Pulse headset solution is to get 2... kinda overkill you might think, but think of the 2nd one as a backup for when you accidentally trash one of the two, you will still have one to use while the other is fixed/replaced. You can always start with just 1 to make sure you like it, you will 🙂
Before the Sony MDR-10RBT I used to rotate between several Sennheiser models - MM450/MM350, and before that several Plantronics headsets - the Sony is the first one with a long enough charge, and sturdy enough that I can depend on it enough to have just 1. I took back my Sony MDR-1RBT as I didn't need 2 for backup.
Sony India doesn't list the Pulse headset in their Playstation gaming area, but someone independent might import them.
Let us know what you find.
I like pulse elite a lot, but in US it os of 100$ and in India it is of 300$,
can u please find the perfect for the gaming, movies etc etc
http://en-in.sennheiser.com/over-ear-headphones
if u find any in sennheiser, please also compare it with Pulse elite
so that i can make my mind what to buy,
Secondly, i have a wired sennheiser which is not comfirtable at all, it just press the corners of the ear and make them hurt, pad are no so soft, thats why running from sennheiser
Thanks
