Audio devices disabled, NEED HELP URGENT
Retired
Not applicable
Hello to you all, i have visited this forum many times for help, and it has been a lifesaver.
To the issue
I have a G73h A1. Tonight i decided to play Dead Rising 2, wich means changing the audio format to 48000hz but the Realtek Audio Driver i installed from the Asus site must of had sth bad for lunch, because i wasnt able to change the audio format from 192000 to 48000. it said error format not supported. so i uninstalled the realtek, and tried to use my stock driver cd. all in all, i gave up from installing it before it got to that, and went back and instaled the high def audio driver from asus.
i restart after the installation, but now my speakers are disabled. i go into the playback devices, the speakers are there, enabled and saying ready. i go into properties, and now the levels tab has NOTHING in it, not to mention the Advanced tab is gone. and whatever i changes i try to make, when i hit apply, are cancelled. ive tried multiple realtek drivers, including the newest ones from their site. NOTHING works. i work with this laptop, and i need it BADLY to work, so id really appreciate anyone who can offer me a solution. i also tried a system restore to BEFORE this whole installing driver things happened, but it doesnt change anth regarding drivers when i do a system restore.
42 REPLIES 42
Retired
Not applicable
nope that didnt work....i should tell you that when i start the computer, and it starts windows, that lil music windows usually plays, even before you log in to a user, isnt playing.
anyway, i guess reinstall it is.
JRd1st
Level 12
I would have reinstalled along time ago. Lol
Read the User's Manual for more info. 😄
G74SX-A1 BIOS 203
Intel 6230 WiFi/BT
LG E2350 LED LCD Monitor
Intel Series 510 120 GB SSD
Drivers, Apps and How To's
Latest nVidia Drivers
JRd1st on DeviantArt.com
JRd1st
Level 12
Thank goodness!
A word of advice: buy Acronis Home Image 2012 right now and make a backup of your system partition. You'll never have to go through this again.
Thanks fo letting us know!
G74SX-A1 BIOS 203
Intel 6230 WiFi/BT
