08-13-2012 10:12 AM - last edited on 03-06-2024 07:51 PM by ROGBot
08-13-2012 10:48 AM
08-13-2012 11:09 AM
cl-scott wrote:
The first thing to test in situations like this is the battery. Both because it's cheaper, and easier to replace than some of the other alternative sources of the problem.
08-13-2012 06:33 PM
08-14-2012 07:00 AM
08-14-2012 07:35 AM
08-14-2012 10:02 AM
brecker wrote:
yw, btw do not remove the battery while it is plugged in and running, it can be dangerous... and using it without battery if your charger is faulty can be dangerous as well...
also on ebay, battery's for your notebook are somewhere between 50-70 usd, perhaps its cheaper for you to get one of those instead of buying it on your country...
08-14-2012 11:03 AM
cl-scott wrote:
Adding or removing the battery while the unit is in operation should have virtually no effect on the unit as far as safety is concerned. The unit can run without the battery just fine as well. The only time that would be dangerous is if there was some other serious issue going on that would be dangerous completely independent of the laptop.
08-14-2012 11:36 AM
