09-26-2012
09:29 AM
- last edited on
03-06-2024
09:47 PM
by
ROGBot
09-26-2012 11:23 AM
Picklejam wrote:
Hi.
I purchased an Asus G55vw in june earlier this year.
About a month later I began to hear a loud screeching sound caused by (what I assume is) the fan when the computer got to a temperature over 55C. The sound got worse over time and soon I found myself getting the noice (a loud screeching sound) even at lower temperatures. I sent my computer in for repairs, got the problem confirmed and the fan replaced, and got it back about a month ago.
Again everything worked fine and quiet (well - as quiet as laptops get) until last week the noise returned again. I am not sure if its actually the fan itself making the sound or just causing it as you can feel vibrations on the computer and pressing down on the front of the computer dampens the sound or actually makes it go away completely until you release.
My question now is: Is anyone else experiencing this problem or am I just unlucky? If you do or did have this problem - what did you end up doing to resolve it.
I have "solved" for the time being by using a coolpad from a previous laptop (lowering the temp enough for the fan not to wind up) but that is not really a permanent sollution. I still have warranty and an extra insurance so I can send it in for repairs again. But every time I do that I am without a computer for 3 weeks which is quite a hassle. (I would also rather just have it fixed/resolved once and for all as I am happy with the computer if it werent for the racket)
09-26-2012 11:47 AM
09-26-2012 11:51 AM
09-26-2012 12:05 PM
dstrakele wrote:
It sounds like there may be some sort of fan clearance issue where thermal expansion is causing the fan to contact the computer housing or some other component to cause the vibration. This is why pressing on the laptop reduces or eliminates the noise and why replacing the fan did not resolve the issue.
I tried to help another G55 user with fan speeds determined by HWINFO64. Unfortunately, from the user's screenshot, the EC sensor with CPU and GPU fan speeds was missing from the Sensors dialog, even though he enabled it. It's worthwhile trying it, but there is a possibility HWINFO64 won't deliver the goods on G55 laptops.
09-26-2012 12:10 PM
09-26-2012 08:31 PM
09-27-2012 12:28 PM
