12-08-2023 02:57 PM
I bought ROG Flow X13 GV301RE (2022 version) on Augustus 23
AMD Ryzen 7 6800 HS
NVIDIA GeForce RTX 3050 Ti
BIOS (327), NVIDIA (31.0.15.1640), AMD (31.0.12028.2002)
other drivers and Windows using the latest update
This month, my notebook experienced several problems:
1. It gets laggy occasionally when I'm using it, and sometimes it turns off itself in every condition
- light work (reading pdf, browsing) or heavy work (playing games)
- on battery or plugged in
- even in performance/turbo mode
I could tackle this problem by restarting/turning it off and on several times. But it still occurs
2. Today (December 8, 2023), when I plugged the charger (battery 20%), the battery suddenly turned 0% and couldn't be charged at all (stayed 0%).
I tried to restart, turn it on/off, hard reset, and follow some instructions here/official ASUS webpage. Nothing works.
Can somebody help me?
12-14-2023 06:15 PM
I faced the lag and turning off issue too, Just used the DIY stand that came with the box for elevation to increase circulation and that fixed it so far.
I suggest you try something similar.
