07-17-2024 10:25 AM
I ran into a problem with the microphone.
One of the problems is that it is impossible to adjust the microphone volume normally, that is, at any microphone sensitivity level, the sound from the built-in microphone is very quiet and as if I am talking from far away.
The second problem is that there is no noise reduction from the built-in microphone. even worse, I can hear the sound of the fans on the recording or online playback.
the third problem is when recording or making an online call, speech or sound from the built-in microphone stutters, that is, it means, for example, if you stretch out one sound "A-a-a-ah", you will hear an intermittent voice "A-.-a-.-h".
Everything I've described is terrible.
All these problems make it impossible to use the built-in microphone during calls or presentations using an internal microphone.
