rog flow z13 audio interface problems
chrisulici
Hi guys,
i'm a music producer and i'm having serious problems while using my Focusrite Scarlett 8i6 connected via USB. It seems like the CPU is constantly overloading, the laptop is overheating and i can't use normal apps like spotify or my DAW Fl studio because of click, pops and glitches. I downloaded Latencymon and the results are crazy, the latency is at a very high level. I tried to set the sample rate and the buffer lenght but nothing changes.
any suggestions? Thank you so much!
0 REPLIES 0
