07-31-2024 11:11 AM
Good afternoon, everyone.
I'm having some very strange problems with my Rog Flow x13 (Ryzen 9, GeForce RTX). Here they are:
When I start typing, it doesn't happen immediately; instead, there is a delay, and sometimes the first letter or the first two letters are skipped (this happens everywhere, in the browser, YouTube, etc.).
I press a letter, and it repeats indefinitely, e.g., ffffffffffffff until I press another letter or the same one again. The keyboard is fine.
I click to open something, and it opens and closes within seconds; the same happens with YouTube. I try to watch it in full-screen mode, and it closes.
I want to clarify that I ran two antivirus and spyware programs and have everything updated, both ASUS and Windows 11 Home x64. It happens with both a charged and discharged battery. I don’t know what else to try. Has anyone experienced something similar? Any help or tips, please?
Thank you!
Solved! Go to Solution.
08-19-2024 03:36 AM
Hello, I wanted to share the solution: I uninstalled Armoury Crate and MyASUS, and the problem went away. Then I reinstalled Armoury Crate without any issues. Best regards.
08-04-2024 07:49 PM
Are you sure you don't have a key stuck / sticky keys or something similar? On a different laptop years ago I had the same problems. Turns out I had some software or setting enabled that was holding down any key I typed.
08-19-2024 03:36 AM
