ROG Flow x13 2023 and Indiana Jones and the great circle
AlexMcAin
First: It works like a charm!!! THANK YOU ASUS for made this little thing make the game run!!!
Second for the rest: the game runs with medium settings in the ROG flow x13 16Gb/RTX 4060 I maxed reflections to high and even if I turn shadows to high they stay the same quality as med, by default is low but med is better and I didn't notice any fps drop for now. 1080p,  ~80c CPU temp. I didn't try to update textures settings of being afraid of not able to run the game (it is in low now) everything else unchanged.
4 REPLIES 4
AlexMcAin
I played just 1h only btw so not too much to say about stability 😄
AlexMcAin
So ok last update: no too much change for now, temp a bit less than ~75 degrees CPU/ ~67GPU(4060), the mem for the GPU rise to ~6.7Gb but I am sure that can run in 6GB RTX..(will try next week.), RAM 16Gb seems enough for running,  the textures look fine, I don't know why needed more BUT probably in 4k TV/screen would have sense. No drops so far of fps, but like many post the cutscenes are sometimes lagging a bit. Sadly on the reflection department/shadows seems not working  at all in raytracing(shadow maps seems only), it is sad since the RTX 4060 is better than the PS5/Xbox GPU. Lastly DLSS active now and looks much better in some parts specially in the hair. I would like to have more tweaks like reduce the fps to 30 so I can add RT reflections...in any case I recommend this game to those out there with this machine or the 2022..for the 2021 I think would look like the Xbox Series S..still good but for the price o the game wait a bit :). Cheers to all who read.
Oh I have armoury crate in performance no need turbo, no need to tweak fans etc etc, and I use the laptop to code raytracing etc etc in my spare time(i have this one from preorder time using it 1/2 times per week ~3hs) so by default should work ok.
AlexMcAin
Sorry for adding another reply 😕 but good news!! ok Sunday I got 2.3GB of update in the game and now all it is better !! shadows are better, lights are better ... all seems better 😄 so give kudos again to the ROG FLOW X13 2023!!!
AlexMcAin
On last little thing..I was able to run Path tracer easily(no mod no nothing just a config file change) with the internal RTX 4060 8GB it looks better for some stuff like glass, while I got ~50fps in the university in the Vatican city started to go down to ~20fps sometimes but didn't care too much in check if I can make it better for now.
