08-11-2025 06:53 PM
I just got this tablet a week ago and am having some very weird stability issues. Blue screens and random resets under certain conditions.
When set to Performance mode or Turbo, logging in results in a BSOD. Under Windows/Silent mode, no issues. Certain games, like Assassins creed shadows or Space marine 2, automatically result in a unlogged hard restart. Regardless of the power mode. SFC /scannow, DISM and CHKDSK report Windows as healthy. 4 passes of memtest86 finds no errors. 3 hours of Prime95 torture testing was stable in Turbo and Performance modes.. 3 Hours of MSI Core Kombustor was also stable with no detected GPU artifacts, Also in Turbo and Performance mode. I have reset the unit back to factory twice with no change in these results.
All drivers are up to date via Armory crate/MyAsus, all windows updates are applied. Bios version is 308.
I'm at a loss as to how to fix this issue, any help would be appreciated.
Solved! Go to Solution.
08-16-2025 10:29 AM
I've faced this with the exact type of SSD. Just upgrade the firmware via Sandisk Dashboard App.
It resolves the issue.
08-14-2025 02:53 AM
Update: It appears that there was a compatibility issue with the WD_BLACK SN770M 2tb SSD. Reinstalling the factory 1tb SSD seems to have resolved the issues.
08-16-2025 10:29 AM
08-17-2025 01:49 AM
Thanks.
